i went to add a hard drive to my computer. i had both of the working. i shut down the system to put it back on the floor. when i booted ut up my original hard drive was not spinning. the hardrive i just installed is working. i have tried different power cables and sata cables
https://linustechtips.com/topic/316226-help/
dat username
LOL
no i can tell that it is not spinning
Have you tried taking out the new HDD just to see if the old one still works?
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/316226-help/#findComment-4298143
i did not remove one. i added one. the new one works. the old one with my os doesnt work
Well yeah, I was just asking. Did you troubleshoot and take out the new HDD just to see if the old HDD still works?
https://linustechtips.com/topic/316226-help/#findComment-4298264
