I travel a lot so I needed a sff case but I want to make a custom case still getting the hang of sketch up
I'm getting the case fabricated for around 100$ but I don't have any parts so please help
Only 400$ left for parts
I know it is less but currently I can't afford more
Please help with the part selection
Also I need windows
https://linustechtips.com/topic/316033-sff-custom-case-build/
Also I need windows
You need a notebook, not an SFF case.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/316033-sff-custom-case-build/#findComment-4295051
I have one I'm building this for fun
Oh... ok.
What exactly do you want out of this PC? Gaming, media center, basic web browsing, video rendering, you name it.
https://linustechtips.com/topic/316033-sff-custom-case-build/#findComment-4295161
K... can you afford it? There are ways to reduce it, but if you can grab this, you are pretty much golden.
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($139.95 @ SuperBiiz)
Motherboard: Gigabyte GA-F2A88XN-WIFI Mini ITX FM2+ Motherboard  ($92.98 @ OutletPC)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($56.99 @ Newegg)
Storage: A-Data Premier Pro SP600 256GB 2.5" Solid State Drive  ($87.99 @ NCIX US)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($33.89 @ OutletPC)
Total: $411.80
Generated by PCPartPicker 2015-02-23 12:32 EST-0500
https://linustechtips.com/topic/316033-sff-custom-case-build/#findComment-4295256
Total: $411.80
Thanks!
https://linustechtips.com/topic/316033-sff-custom-case-build/#findComment-4295363
