Hi everyone, I have what I hope will be a relatively simple question to ask. I have recently finished building my pc, and I am wanting to put some LED strip lighting on the top and bottom of the case. I'll need 2 x 30cm LED strips, in white light and as bright as possible. Does anyone know where I can get these? I wanted to be able to plug them into a molex connector from the power supply, and I just wanted them to be at a set brightness, preferably quite bright, without a controller. Thanks in advance!
https://linustechtips.com/topic/315906-led-strip-case-lighting-help/
You can get Bitfenix alchemy
i use these: http://www.deepcool.com/product/dcoolingaccessory/AccessoryRGBLED/index.shtml
the white is very bright, but you can dim them down. You also have the benefit of the full range of RGB if you fancy a change.
I dont know your location but Canada Computers sells them here
i5 4670k @4.2ghz / MSI Z87 G45 / EVGA GTX 960 SSC / Samsung  840 EVo SSD / WD Green 1tb HDD / Corsair H75 / Corsair Obsidian 750D / Corsair CS750M
These look perfect!! . . . . only it wont ship to Australia :/
EDIT: Lol yes they do sorry
Edited by Warren Pnigel
  • 2 months later...
Did the seller turn out to be trustworthy? Considering ordering some for myself.
Dubs are better than subs
Yes they were trustworthy, and nothing was missing/broken. They turned up pretty quickly for ebay. I would however recommend getting rgb strips, just in case you get sick of one colour. However if you are 100% on a single colour, these are probably the cheapest and best option.
Grab strips from add on customs (@Marcus_UK) they're gonna be much better quality than the ones from ebay
Asus MAXIMUS VII Gene 2 x 8GB G.Skill 16GB 1600 Mhz Intel 4670k @ 4.3 Ghz Corsair H100i w/ stock fans EVGA GTX 770 SC Intel 750 Series SSD 240GB, Samsung 840 SSD 240GB WD Caviar Green 2TB Seasonic X-650 V3 2 x 140 mm Noctua A14 PPC, 120mm LED Corsair AF120
