I would use Displayport, but DVI would work as well
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/315352-connector-help/#findComment-4285881
Don't forget to enable 144Hz refresh rate in settings.
Like stated above DVI and DP are the best options
(I'd personally use DP though)
The connectors on the monitor only have HDMI, DVI-DL and D-sub. So i was thinking would it still work if i use a HDMI cable but use a DP to HDMI adapter ? Or go with DVI ?
https://linustechtips.com/topic/315352-connector-help/#findComment-4285927
Silly :P You put in the first post that there was DP
But in that case, I'd just use DVI :)
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/315352-connector-help/#findComment-4285938
I don't think HDMI>DP converter will be able to push 144 Hz. Go with DVI.
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/315352-connector-help/#findComment-4285941
