HELP - Boot Drive becoming Full.
Solved by Konrath,
1)Create corresponding folders on new drive (Documents, Downloads, Pictures, etc)
2)Open My Computer
a)Right click folder (Documents, Downloads, Pictures, etc)
b)Left click properties
c)Click Location tab
d)Set location to new drive path (E:\Documents for example)
e)Click OK or Apply
3)Either cut or shift+click to move files to corresponding folder on new drive.
You can also create a Programs folder on the new drive and install your games there. That is how I have mine set up.
