300 dollars for a editing pc even a amd cpu is a bit over budget
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/314337-cpumotherboard-advice/#findComment-4273237
^ This. You'd need at least around 500. (For a descent one at least)
Case Phanteks Enthoo Evolv ITX | Motherboard Asus ROG Strix Z270i | CPU Intel i7-7700K | RAM Team Vulcan 16GB DDR4 | GPU Geforce GTX 1080 Ti | Storage Crucial MX300 1TB M.2 | PSU Corsair RM750x
https://linustechtips.com/topic/314337-cpumotherboard-advice/#findComment-4273264
