Hi ! I have an issue with my new Samsung 3 Series laptop. i know for sure the fan works : when the cpu and/or gpu get hot, the fan speeds up ! But i'm not satisfied with the way it's configured. (the temps are around 50° celsius at idle !!) And whatever program i get, i can't manage the fan speed !! the fan isnt detected at all !
Any idea ?
https://linustechtips.com/topic/3140-laptop-ghost-fan-issue/
Yep - check BIOS - there is sometimes an "idle fan" setting, which may be at off or low. Sometimes you can change this and make it higher...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/3140-laptop-ghost-fan-issue/#findComment-40517
Well... nothing in the BIOS. Guess what ! I was unable to access the BIOS when i turned on the PC ! No key proposition ! so i tried DEL, F2, F12... didn't work. I managed to access the BIOS by entering first the Win8 settings... so weird. (i'm sure i can enter the BIOS before Windows 8 starts but i didn't find the key...).
Anyway, the BIOS is so poor... i didn't find anything about ventilation... :(
https://linustechtips.com/topic/3140-laptop-ghost-fan-issue/#findComment-41084
