Not too loud, maybe replace the 140MM fan, and get noise isolating headphones if it becomes too bad. There's some creaking if it's moved or gets hot and starts cooling. It's a great case though, love mine.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/313883-enthoo-pro-noise/#findComment-4266788
Does it have rubber mounting holes for the fans?
I'm looking into the enthoo pro or the luxe if money permits, I'm just worried about sound. W/ college its tough because I'd hate to have a noisy system on and I typically have my systems on all the time unless I'm leaving my house (I always fall asleep watching netflix in bed)
https://linustechtips.com/topic/313883-enthoo-pro-noise/#findComment-4266805
No, you can buy some, but you'd also have to buy new fans because the included ones don't support isolating rubber mounts.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/313883-enthoo-pro-noise/#findComment-4266827
Nah, the case is incredibly quiet.
I have two different AIOs in my system, 11 fans in total, and it is at head level on my desk.  I do use rubber grommets instead of screws whenever able, but overall, its not loud at all. There is no better case on the market at the $100 price point.  The H440 and Define R4/5 might be more silent, but you get really poor airflow as a result, and less features.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/313883-enthoo-pro-noise/#findComment-4266972
