Enthoo Pro is big, H440 is quiet. What do you want?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/313876-enthoo-pro-vs-h440/#findComment-4266671
A lot of people like the look of the h440 but I think it is bleh, the psu shroud in it looks tacky and cheap.
I personally think the enthoo pro screams: "I'm big, I'm beautiful, and I'm sleek." Something that a lot of case manufacturers aim for, but fail to deliver.
The older brother to the pro, the luxe is absolutely amazing looking and imo, performs just as well as any case in that price range.
But if you're looking between the enthoo pro and the h440, I believe it all comes down to what you're looking for. Literally, what do you wanna see? The h440, or the enthoo pro? The h440 might be more quiet as EarthboundHero states, but sound can be fixed by replacing case fans for a few extra dollars down the line if you actually can hear the fans.
https://linustechtips.com/topic/313876-enthoo-pro-vs-h440/#findComment-4266695
quiet
Alright the H440 will be quieter, cable management is harder. The Enthoo Pro is big, a bit louder (Not too much if you have good headphones) easy to cable manage and has ODD slots.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/313876-enthoo-pro-vs-h440/#findComment-4266697
air cooling/AIO or custom watercooling?
h440 has three forward fans, insulated front panel cover them to muffle the fan
noise. can be restrictive if powerful replacement fans installed.
enthoo pro has 200mm (2x 120/140) with an open mesh. can be a louder case
if using 2x 120/140.
both have fan hubs. pro is a full tower and h440 is a mid tower.
i have all three (750D too) and personally like the pro for the price point. if
you are a dust freak, the pro is not for you. all three do a good job on silence,
but the h440 is muffled a bit better. if using the h440 i suggest a blower GPU
over the open fan cards. the pro and 750D doesn't matter.
https://linustechtips.com/topic/313876-enthoo-pro-vs-h440/#findComment-4296702
