Hello, do you have 3 pin fan headers on your motherboard?
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/312601-cheap-fan-controller/#findComment-4248777
If you had more than 1, this could help: http://linustechtips.com/main/topic/154956-how-to-properly-set-up-speedfan/
Even with 1, you can control it, but a fan controller would be a better alternative.
https://linustechtips.com/topic/312601-cheap-fan-controller/#findComment-4248900
