Hello,
My name is Alan Christianson and I have been a gamer for many years. I've researched building a computer for about 3 years now and have finally decided to get a job to work for a $1,500-2,500 gaming setup for gaming, video editing and programming/designing video games. There is one problem and that is I know a Intel Core i7 is a better CPU then a Intel Core i5 and that CPU means Central Processing Unit, but i don't know what a i7 is better than a i5 if you see what i'm saying.
I'm looking to build a gaming computer and i'm going to list several of each computer piece i'm looking at and I don't know if any 2 pieces won't work well together. (These pieces are off Linus 4k computer and all around computer videos) I need your help on wether something is a bit excessive and wether or not I can use half of the 4k videos computer pieces and half of the all around gaming video, computer pieces.
The games i'll be looking to play on these computer would be games like World of Warcraft, Starcraft 2, Advance Warfare. The reason I want to build a computer is because as of now I have a macbook pro and I don't really want a laptop and was hoping to get something I would look more forward to.
(Prices are fairy accurate)
Case: Still looking into it, I'm thinking the one linus uses in 4k computer build.
CPU:
Intel Core i7 4790k (unlocked quad core processer with hyperthreading) $320
Intel Core i7 4730k (unlocked quad core processer with hyperthreading) $568
Motherboard:
Asus X99 WS    $480
Asus Sabertooth 297MK1 $180
Asus X79 Deluxe   $322
Ram:
32 GB Corsair Dominator Platinum 2133MHz Dual Channel DDR3 $460
32 GB G. Skill 2400MHz Quad Channel DDR3   $430
SSD:
1x Intel 730 Series 240GB SDD $170
2x Intel 730 Series 480GB SDD in RAIDO $350
Video/Graphics Card:
Dual Gigabyte Radeon R9 290 4GB Windforce Cards in Crossfire $360
Duel GeForce GTX 780 Ti Reference Cards in SLI $530
MSI Graphics Cards GTX 980 Gaming 4GB $560
Power Supply
Corsair AX1500i Power Supply $400
Corsair AX1200i $300
Cooler Master V850 $170
(I know I did not include coolers and fans as I have not yet done research into those two things)
Now that you've seen what I'm looking at my ideas is the more expensive CPU with the Deluxe motherboard and I don't know what RAM to get, for SDD i would say the 2x and for graphics I'm also unsure, then for power supply i'm thinking the Corsair AX1200i.
As for as graphics are concerned I don't really want 4k resolution but it would be nice to have some good quality. I'm looking for a roughly 32" HD Monitor. I would also like your thoughts on having 1-3 Monitors as I'm always switching from different programs and windows while gaming and I'm hoping to have 2 monitors.
Update: Please let me know if anything here will prevent a future update or if there is a different piece I should buy instead of the one i've listed.
Cringe so bad.
The Intel 4730K doesn't exist.
Also, none of the X99 or X79 motherboards will fit a 1150 socket processor mate.
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
I think you should start using https://pcpartpicker.com/ if you don't know about compatibility between the parts you are about to buy, also watch some linus videos...
I Never see 297 Chipset and i7 4730k
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
the case linus use for 4K Build is 760T By corsair
1.8k should be fine for 4k gaming build (exclude monitor)
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($128.99 @ SuperBiiz)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($139.99 @ Micro Center)
Storage: Crucial MX100 512GB 2.5" Solid State Drive  ($199.99 @ Adorama)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (2-Way SLI)  ($347.99 @ Amazon)
Case: Corsair 760T Black ATX Full Tower Case  ($169.99 @ NCIX US)
Total: $1834.89
Generated by PCPartPicker 2015-02-18 02:52 EST-0500
Cringe so bad.
Meant the 4930k http://www.amazon.com/gp/product/B00EMHM622/ref=as_li_qf_sp_asin_il_tl?tag=linustechtips-20&ie=UTF8&camp=1789&creative=9325&creativeASIN=B00EMHM622&linkCode=as2
Gonna build one now, I've been meaning to use this site.
