My system will not post?
Go to solution Solved by Dumprukk,
Fixed the problem....installed the ram in the wrong dim slots (facepalm*) i feel so embarrassed but things could of been worse...Thanks LTT community!
For some reason nothing will show up on my monitor, after i installed the cpu, and everything else for a test boot. I am sure i have everything plugged in, but nothing will show up on screen. My mobo is a ASUS MAXIMUS VII HERO and all the LEDs and things light up, when i turn the system on via the start button on the mobo, the led code on the motherboard says "FE" i dont know what this means. I have the DVI plugged in to the on board graphics port on the mobo and the monitor. Did i bend a mobo pin? i put the CPU as gently and lined up as possible... What do you think happened? HELP
https://linustechtips.com/topic/312508-my-system-will-not-post/
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/312508-my-system-will-not-post/#findComment-4247538
Check your motherboard manual for what FE means
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/312508-my-system-will-not-post/#findComment-4247540
Its either a problem with ram, bent CPU pins, or not having your standoffs installed.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/312508-my-system-will-not-post/#findComment-4247556
What does the standoffs have to do with anything?
If there are no stand offs the motherboard will ground off the steal case
https://linustechtips.com/topic/312508-my-system-will-not-post/#findComment-4247612
Your welcome, glad you got it fixed
https://linustechtips.com/topic/312508-my-system-will-not-post/#findComment-4247723
