Hi i am new to VBS and would like to change the background color, text color and button color of this input box
fso = InputBox("To verify that you are the correct user please enter your password.", "License Key list")
Thanks in advance for any help i get xD
full code:
if fso <> "qwerty" then
lol=msgBox("The password you entered was incorrect.",16,"Error")
wscript.Quit
end if
msgBox("License key:123456789")
if fso = "x" then
end if
https://linustechtips.com/topic/312485-help-with-vbs-codding/
Moved to Programming & Software Design.
EDIT: Sadly, I don't believe that you can change that for the InputBox, if you want to make it custom you will most likely have you make your own custom form for input.
Edited by Blade of Grass
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/312485-help-with-vbs-codding/#findComment-4254692
