Hi. Im having a problem making cooling configuration for my current build. Its mATX that would be put inside Phanteks Evolv. SInce I`ll be going for an SLI in mATX case, i decided to cool my GPU-s with 2 kraken g10 coupled with 2 kraken x31, and x41 for CPU. Would that cause me problems with air pressure in case/dust since I`d be using 1 top and rear 140`s as intake with 2 front 120`s and 1 top 140 as exhaust (all 3 with rads)? It`s really killing me as i was so close to having no doubts about my new build, so any help is welcome :)
https://linustechtips.com/topic/312072-intakeexhaust-problem/
Use filters if you are afraid from dust or positive pressure as you may know.
when you start building start tinkering with configuration and see your temps, I would be glad to help if you going to do that.
I would say put the rear one as intake and both fans at top as exhaust and both in front as intake.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/312072-intakeexhaust-problem/#findComment-4241479
I was thinking about making front as intakes, but since gpu-s put out a lot of heat, would that make inside of case a bit to hot for other components? If not I would go x61 for cpu instead of x41...
Build link http://de.pcpartpicker.com/user/shomy993/saved/#view=bpDfrH
https://linustechtips.com/topic/312072-intakeexhaust-problem/#findComment-4241663
