I'm wondering what a D5 pump with no speed control is rated at? I'm going to be using a Lamptron FC5v3 to power the pump and the fan controller is rated at 30w per channel. Will I be able to run the pump on the controller?
What D5 pump specifically? I'd assume most would work on that controller. This one for example is 2A @ 12V which would mean 24W. http://www.frozencpu.com/products/17644/ex-pmp-220/Alphacool_HF_D5_Top_-_Black_Acetal_w_Swiftech_MCP655-PWM_Pump_Installed.html?tl=g30c107s1802&id=kZUcnUid#blank
"Rawr XD"
https://linustechtips.com/topic/311844-d5-pump-wattage/#findComment-4238460
I have the variable speed Laing D5, and its rated for 8-33w. I'm pretty sure at 12v it only uses 22.8w(12v x 1.9a = 22.8w), but I could be wrong.
https://linustechtips.com/topic/311844-d5-pump-wattage/#findComment-4238465
specifically like this one: https://www.dazmode.com/store/product/dazmode_storm_d5_strong_8-24v_pump/
https://linustechtips.com/topic/311844-d5-pump-wattage/#findComment-4238470
