So I'm looking to build a computer at around $1000 (with in $100 above or below) which I was told is the "sweet spot" for a PC.  I have decided on everything so far aside from the graphics card.  However,  I have narrowed it down to two options.  Either the ASUS GTX 970 STRIX or the 960 STRIX.  I am planning on using this computer for editing (not 4k just like 1080p in sony vegas),  playing games such as BF4, Far Cry 4, etc, and a little bit of 3ds max.  Is getting the 970 worth the price for what I am doing or should I stick with the 960.
The specs I have decided on:
i5 4460
8gb Vegeance Ram
MSI H97 Guard Pro
CX600 PSU
MX100 256ssd
1TB Seagate Barracuda
and a Fractal Design Define R4
If there is anything about the specs above that I should change please tell me aswell.
Thanks in advance,
https://linustechtips.com/topic/311281-best-gpu-for-my-purpose/
I would say the sweet spot is 1400 but to each his own
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($96.98 @ Newegg)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($293.98 @ Newegg)
Total: $1114.09
Generated by PCPartPicker 2015-02-15 23:29 EST-0500
https://linustechtips.com/topic/311281-best-gpu-for-my-purpose/#findComment-4230573
I think the 970 is worth the extra investment over the 960. The 970 has more vram and more processing power in case you need it later on down the road.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/311281-best-gpu-for-my-purpose/#findComment-4230741
i5 4460
8gb Vegeance Ram
MSI H97 Guard Pro
CX600 PSU
MX100 256ssd
Thanks in advance,
I would go with keemos build, it's great and the 290x and i7 will be better in the long run.
Rose's are red violets are blue, without computers I'd know not what to do.
https://linustechtips.com/topic/311281-best-gpu-for-my-purpose/#findComment-4230920
