I bet this is a really dumb question but if you look on pcpartpicker and go to r9 280s there is two sapphire versions that look exactly a same just a slightly different name and same price tag. Thinking this just might be a mistake on the website's part but I don't know, just want to make sure if i'm getting the right one sense I'm getting a sapphire r9 280.
http://pcpartpicker.com/parts/video-card/#c=167&sort=a8
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/310967-difference-between-these-two-gpus/
Maybe it's a 2nd gen of the same card?
yup that's the truth.
its probably the 2nd iteration of the card hence the 100373L becoming 100373-2L and the 2nd one is shorter in length with only 10.28" rather than 10.31"
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
so which one do I purchase?
both are basically the same card. but the newer release is probably better
which one is the newer one?
the one with -2L on the end, most likely.
I looked really hard, and the differences seem minor, but the -2L may have some tweaks that either cut manufacturing costs, or improve performance. the length and width changes may be human error as they are so close.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
