Sit next to an open window :P
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
https://linustechtips.com/topic/309701-please-help/#findComment-4209820
hahaha , is winter now :)
thats the point....
what laptop/cooler do you have?
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/309701-please-help/#findComment-4209883
now my cpu temsp got up to 65 and the first task was firefox
 I have an hp pavilion g7 and a spire alluminum cooler
the cooler, is it just one large fan?
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/309701-please-help/#findComment-4209922
This was posted on the HP forums. Dust buildup between the headsink and fan might be your problem as well.
Hi
I just fixed this problem with my hp d7 Pavilion
I was having the same problems discribed here. After about a year the fans running all the time, very loud. It was getting really hot on the left side and burning my fingers. It even shutdown once due to overheating.
I started reading forums and getting worried because it seems like everyone was having this problem. Maybe I made a bad purchase... to bad I really liked my laptop.
So then I figured what the heck, its going to die anyway might as well open it up. I'm an electronics tech in the navy, I should be able figure this out.
So I went online and found a youtube video that showed me how to open it. This video was not quite right as I learned, but it was close enough that I figured it out. (some of the screws were in different places, and it had 2 hard drives. I only had 1)
Once I got it open I still couldnt tell what was wrong. It looked clean inside, and nothing was melted, or damaged in any way.
Eventually I lifted up the motherboard and got ahold of the fan. Still looked clean, but there was a heatsink attached to the side of the fan, and it looked like there was a tiny bit of dust in between.
So I took apart the fan, and found a solid wall of dust and hair between the fan and the heatsink. It was blocking almost all the air from getting through. I pulled it out with some tweezers and put my laptop back together.
Its running as good as the day I bought it.
I'm not sure if I could have knocked that wall loose by blowing air up into the fan, or not. if you catch it early enough, it should work, but if you are to late I dont think it will work, and you might have to pull it apart.
If you dont feel comfortable pulling apart your laptop you could probably just direct the repair shop to look between the fan and the heatsink, because unless they pull the fan itself apart, they wont see it. It looked perfectly clean, and the fan has a grey foam around it that blends in with the dust, so its hard to even see the dust.
I hope this helps some of you out there.
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/309701-please-help/#findComment-4209958
no 2 small
fan xpert?
now my cpu temps got upto 100
what programs do you have running besides Firefox?
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/309701-please-help/#findComment-4209976
Looks like dust is doing it's job. Find nearest pc repair shop and ask them to clean it if you don't want to do it yourself. Here it costs up to 20EUR. You should clean your laptop at least once a year, especially if you like to use it on beds, carpets and other soft surfaces where dust likes to collect. Regular cleaning will help your laptop to run quieter, cooler (hence faster) and add a year or two to it's lifetime.
I am sorry for my english.
https://linustechtips.com/topic/309701-please-help/#findComment-4210102
I will clean it by my self
I am thinking of installing fanspeed and controll my fans
https://linustechtips.com/topic/309701-please-help/#findComment-4210125
there are plenty of videos on youtube that show you how to do it. There isn't much to worry about.
Edit:
https://www.youtube.com/watch?v=UaH4GLDHgms
5.1GHz 4770k
My Specs
https://linustechtips.com/topic/309701-please-help/#findComment-4210228
