Nope. Galaxy Gear only works with Note 3, Note 4, S4(Not Sure) or S5 upwards
Computer Specifications:
AMD Ryzen 5 3600  Gigabyte B550M Aorus Elite | ADATA XPG SPECTRIX D50 32 GB 3600 MHz | Asus RTX 3060 KO Edition CoolerMaster Silencio S400 Klevv Cras C700 M.2 SSD 256GB
1TB Crucial MX500 | 1 TB SanDisk SSD Corsair RM650W
Camera Equipment:
Camera Bodies:
Olympus Pen-F Panasonic GH3 (Retired)
Lenses:
Sigma 30mm F1.4 | Sigma 16mm F1.4 | Sigma 19mm F2.8 | Laowa 17mm F1.8 | Olympus 45mm F1.8 | Panasonic 14mm F2.5
https://linustechtips.com/topic/309027-galaxy-s2-help/#findComment-4200567
i have a galaxy s2 and i put omni version 4.4.4 kitkat on it the reason for this is to use my new galaxy gear will it work ?
Technically it will work, by sideloading Gear Manager onto your device, however only basic functions will work, many Touchwiz-based functions such as weather and music won't work when not using a supported device.
http://jeanlucdavid.com/2013/11/installing-samsung-gear-manager-on-google-nexus/
That link doesn't even lead to anything.
"Rawr XD"
https://linustechtips.com/topic/309027-galaxy-s2-help/#findComment-4215100
