Need a little help picking display.
Hey folks!
So basicly i am a huge fan of euro truck sim and i kinda need an upgrade beacuse playing on 2 Dell 2412M kinda doesnt work as it should. I had an idea of buying widescreen. Monitor would be Asus PB298Q it is 2560x1080p 21:9 monitor. MY dells are 1920x1200. how would that react together?
Also asus is 21:9 29 inch dell is 24 16:10.
big confusion :D
>WaRRioR_ would like quake full and final....will trade vital organs.\"
5960x, rampage v extreme, 2x 16Gb ddr4 g skil 2400mhz ram, 2x 2tb black WD, 4x samsung pro 256Gb, 3x gtx 980 evga superclocked, Corsair ax1200w, define r4, noctua nhd15, 4x dell u2412m....
https://linustechtips.com/topic/308570-need-a-little-help-picking-display/
if your planning on buying a wide screen monitor you might want to go to a best buy or electronics store that has one before you buy
I stopped into tiger direct and see one of the smaller wide screens and it looked stupid. Now the 34inch  that Linus reviewed  would't be so bad because its taller.
So if you look and see that that monitor will fit you then get it but seeing it on a web site and seeing it in real life are 2 different things
https://www.youtube.com/watch?v=KnrxNfxRK_4
