Mayhems Pastel Coolant Premix - 1L - Green PrimoChilll 1/2" OD Rigid Revolver Compression fitting 10 pck
Monsoon 1/2" OD Hardline Tube - 4x 24" Pack -Clear
Bitspower Water Tank Z-Multi 150 Inline Reservoir - Clear
Alphacool NexXxoS XT45 Full Copper Dual 120mm Radiator
EK Supremacy EVO Universal CPU Liquid Cooling Block - Plexi
Swiftech MCP50X Liquid Cooling PWM Pump - Black
First time doing watercooling. Need help with fans, could I use stock ones that come with my case (NZXT H440 designed by razer) or should I purchase others. If so which ones. Also this is only going to be a CPU loop, is what I have listed above to much or not enough? Will everything work togeather like the tubes and fittings? Sorry for all the dumb questions but thank you for taking your time to read and reply.
http://pcpartpicker.com/p/hHL423
My rig.
No H220X
<p>CPU: Intel i7 4790k(4.9GHz), Motherboard: ASUS sabertooth Z97 Mark 1 RAM: Corsair Dominator Platinum 16GB (2 x 8GB) GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 (2 way SLI) PSU: EVGA 850w G2 Storage: Intel 730 Series 240GB 2.5" SSD, Western Digital Caviar Black 1TB Case: NZXT H440 Designed by Razer, EK,Alphacool,Bitspower custom loop.
“Peace cannot be kept by force. It can only be achieved by understanding.”
Albert Einstein 14 December 1930
https://linustechtips.com/topic/308472-first-watercooling-build-help-please/
If you want to do water cooling, you can use that stock fans. But if you want better, you can get like noctua (they're great). When you try to fill the reservoir, make sure the coolant can get into the pump otherwise the pump can break. Before proceeding, MAKE SURE you've jumped the PSU just put paper clip to the green wire to any black wire. Don't close the reservoir yet because you need to have air go in so the flow is nice, when you plug the cable the coolant should flow. When the coolant in the reservoir is like half way empty unplug the cable and refill the coolant, and repeat. If you're still confused you can see this video: https://www.youtube.com/watch?v=Dk3V64ZSsEI
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
Thanks ill check out the video.
2 120 45mm thick rads are more than enough for cooling your cpu.You will be fine with only using a single 120 45mm thick rad,so the case fans are good enough,plus the fpi or fins per inch is pretty low as well,meaning you need less static pressure to move air through.So in my opinion,go with the case fans.
