If you want to servo to be able to do a full rotation you are going to have to mod it.
CPU: i7 4770k | GPU: Sapphire 290 Tri-X OC | RAM: Corsair Vengeance LP 2x8GB | MTB: GA-Z87X-UD5HCOOLER: Noctua NH-D14 | PSU: Corsair 760i | CASE: Corsair 550D | DISPLAY:  BenQ XL2420TE
Firestrike scores - Graphics: 10781 Physics: 9448 Combined: 4289
"Nvidia, Fuck you" - Linus Torvald
https://linustechtips.com/topic/30832-arduino-programing/#findComment-394768
Not necessarily, there are continuous rotation servos such as
http://www.parallax.com/tabid/768/productid/102/default.aspx
https://www.sparkfun.com/products/10189
https://www.sparkfun.com/products/9347
But you can also mod a regular servo
In terms of controlling it, it's a matter of sending a PWM signal accordingly to the datasheet specs
Keep in mind that continuous rotation servos don't allow to control a rotation angle, you can only control the rotation speed
https://linustechtips.com/topic/30832-arduino-programing/#findComment-394895
