I'm not getting the actual fan control that I see in videos and other examples. I've seen people say things like "disable fan control in your BIOS" but looked and couldn't find that option either. System specs in signature. Thanks m8's.
yitnowowrkm8
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/308315-speedfan-help/
If your motherboard doesn't support manual fan control, then it's to be expected. OR in the case of a lot of those boards, there is a 3rd party piece of software that does the controlling, not speedfan.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/308315-speedfan-help/#findComment-4190212
See that's the problem. Gigabytes custom fan curve software literally doesn't work. They don't support it.
https://linustechtips.com/topic/308315-speedfan-help/#findComment-4190233
Last time i used SpeedFan was on Windows XP.
It's an awful, outdated piece of software.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/308315-speedfan-help/#findComment-4190237
Well, is your bios updated to version F5?
That may add the option you seek. SpeedFan sucks... just fair warning. You COULD use afterburner to set up a curve, too.
https://linustechtips.com/topic/308315-speedfan-help/#findComment-4190267
