Hey guys, looking to build a "strictly for gaming" Mini-ITX machine capable of pumping out the high fidelity frames at 1080p. I've thrown this build together, any ideas/suggestions? Not planning to overclock for improved thermals (Hence the "non-k" 4690,) please don't recommend an SSD, I'd rather have 1TB of slow storage than 120GB for the same price. Thanks for your input. :) (Budget is $700)
http://pcpartpicker.com/p/FDgC99
https://linustechtips.com/topic/308173-mini-itx-gaming-machine/
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($171.99 @ SuperBiiz)
Motherboard: ASRock H81M-ITX Mini ITX LGA1150 Motherboard  ($53.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($324.99 @ SuperBiiz)
Case: Thermaltake Core V1 Mini ITX Tower Case  ($39.99 @ Newegg)
Power Supply: SeaSonic 400W 80+ Bronze Certified ATX Power Supply  ($39.99 @ SuperBiiz)
Total: $753.93
Generated by PCPartPicker 2015-02-10 17:55 EST-0500
https://linustechtips.com/topic/308173-mini-itx-gaming-machine/#findComment-4188154
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor  ($238.99 @ SuperBiiz)
Motherboard: ASRock B85M-ITX Mini ITX LGA1150 Motherboard  ($67.98 @ Newegg)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($31.99 @ Micro Center)
Total: $826.92
Generated by PCPartPicker 2015-02-10 17:48 EST-0500
What? A Xeon and total cost is $826? Can't tell if you're trolling or not -_-
https://linustechtips.com/topic/308173-mini-itx-gaming-machine/#findComment-4188169
Im sorry?
The part list is right there.
I think i didnt miss anything.
https://linustechtips.com/topic/308173-mini-itx-gaming-machine/#findComment-4188176
Try and fit in a ssd if you can manage, that is always a good thing other than that id suggest getting an r9 280x over the gtx 960 they are at the same price point and the 280x is better
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
https://linustechtips.com/topic/308173-mini-itx-gaming-machine/#findComment-4188195
oh and if ur gaming then the speed of ur RAM aint gonna make a blind bit of difference tbh so try an find cheaper ram clocked at 1600 mhz if u can
https://linustechtips.com/topic/308173-mini-itx-gaming-machine/#findComment-4188204
Yes I can see it, but a xeon is not practical for gaming and the total cost is $826 when I specifically said $700
Fixed it.
Total: $753.93
https://linustechtips.com/topic/308173-mini-itx-gaming-machine/#findComment-4188210
