Help with a build
So guys I need help with a build for roughly $1,000 Australian I have a general idea of the parts but suggestions are appreciated budget like I said is $1,000ish can go over a bit. This is what I have already http://au.pcpartpicker.com/p/cB4PGX
Cheers guys
Should mention I already have the 270 and the i5 is a must
A couple of minor suggestions. An H97 motherboard since the cpu will not overclock. A different memory kit that has slightly better timings and color to match the motherboard. Unless the system will live in a room that tends to get quite hot, the stock cooler will do a good job. A decent 240GB ssd. The larger the ssd the better, IMO.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($243.00 @ Centre Com)
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard ($129.00 @ Mwave Australia)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($94.00 @ IJK)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive ($125.00 @ Centre Com)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($68.00 @ CPL Online)
Video Card: MSI Radeon R9 270 2GB TWIN FROZR Video Card (Purchased For $135.00)
Case: Corsair SPEC-03 Red ATX Mid Tower Case ($79.00 @ CPL Online)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply ($92.00 @ CPL Online)
Total: $965.00
Generated by PCPartPicker 2015-02-10 17:41 EST+1100
