Hey everybody, i need some help customising a pc that i will be using for gaming and other use such as youtube, facebook and homework.
I will be playing games at 1080p, i already have a monitor, keyboard and mouse.
The games I will be playing are minecraft with shaders mod, planetside 2, ps2 and maybe next gen emulators (for kingdom hearts 1,2, and 3!)  and possibly bf4 or cod ghosts.
And even though i probably wont play these following games it would be nice to know i can run them (30-40 fps medium settings) :
Skyrim, Borderlands 2, Far Cry 3
I dont need to max them out, medium settings at 30-40fps is fine.
Probably wont overclock so a cpu cooler is not absolutely neccessary but if you can fit it into my budget thats great!
All i need is the pc, a wireless adapter, and an os.
My budget for this is 1300 nzd (if possible use the free shipping options)
Please use nz.pcpartpicker.com to customize me a pc with all i need.
Thank you all for the help!
ps: if it helps this is what i have come up with so far : http://nz.pcpartpicker.com/user/Photon_Debugger/saved/1P54
FX 6300 | Sapphire 7770 | G-Skill Ares 8GB | WD Blue 1TB | ASUS M5A78L-M
Tritton Kunai | Logitech Proteus Core G502 | Razer Blackwidow Tournament
https://linustechtips.com/topic/30697-first-build-help/
Seems good but get a 760
I agree
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/30697-first-build-help/#findComment-392996
I agree
Unfortunately the 760 isnt out in new zealand yet and the 7950 is like 400 dollars. freaking sucks
https://linustechtips.com/topic/30697-first-build-help/#findComment-393026
https://linustechtips.com/topic/30697-first-build-help/#findComment-393813
  • 2 weeks later...
Where are you getting your 7950's that they're only $400?
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/30697-first-build-help/#findComment-444082
