i own a samsung evo 840 120g ssd.
around 100ish after windows installed. i dont know what is filling it all up. It has 10g left on it and when i go into my C drive(which is the SSD) and Highlight everything to hit properties to see the size of all those files only show 32.5G in that soooo where is all that other data at?
https://linustechtips.com/topic/306964-storage-issue/
Hey Rawrz007,
Could you post some screenshots of your disk management and my computer? Do you have any programs that are installed on the SSD that might be doing writing to the drive or some hidden files?
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/306964-storage-issue/#findComment-4174235
