Cpu temp question.
Solved by Godlygamer23,
That's the number you want to focus on. I have a 3570K and its T-case temp is 67.4 degrees C. I've gone past that with another cooler for long periods of time - nothing happened to the chip. TJ Max is the temperature that the actual die can take before melting.
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
