I recently bought a r9 270 off of ebay, and I tried to switch out my gpu that I have now for it, but when I did, my monitor wouldn't turn on. My tower has a built-in screen on it, and it said "Memory modules are found, but an error has occured." I was thinking it was my power supply, but if that was the case, I don't think the gpu fans would've been spinning. I know my PSU isn't good, but I don't have the cash for it since I just bought the 270. As of now, I have a ATI 3600, and a Intel Q6600. Can someone help?
https://linustechtips.com/topic/306892-r9-270-problems/
The R9-270 is several magnitudes more powerful than a HD 3600 graphics card, but draws a significantly bit more power.
As mentioned by @CoolaxGaming, please upload a picture if the internal of your system, showing the power supply.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/306892-r9-270-problems/#findComment-4169907
