Floppy Power Connector
Go to solution Solved by Uphorics,
Wow... no posts... anyway...
The only thing I can think of using the floppy connector anymore is if you wanted to add lights or something to your case and use that as an adapter.
Other than that, no, it's useless. It's simply there because they can.
CASE: Phanteks Enthoo Pro // CPU: Intel Core i5 2500K @4.2GHz // GPU: NVIDIA GeForce GTX 970 Reference // RAM: 16GB Crucial Ballistix Sport @1333MHz // MOBOASUS P8Z77-V LK // SPACE: 240GB Crucial M500 SSD ~ WD Black 1TB // PSU: Corsair CX750M //
CASE: Cooler Master Elite 130 // CPU: Intel Pentium G3258 @4.0GHz // GPU: N/A // RAM: 8GB Crucial Ballistix Sport @1600MHz // MOBOEVGA Z87 Stinger Mini-ITX // SPACE: OCZ ARC 100 120GB SSD ~ [2X WD Black 2TB in RAID 1] // PSU: EVGA 430W //
https://linustechtips.com/topic/306179-floppy-power-connector/#findComment-4165734
I think some sound cards use the floppy connector. I may be wrong though.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/306179-floppy-power-connector/#findComment-4167315
