Good air cooling cases?
Solved by Guest,
I know the Define R5 is popular here and I looked into it even before I started the thread. Its very quiet but the tradeoff for temperatures isnt worth it to me.
At first I wanted a big case but I think the FT05 will be enough. Price between Corsair 450D and Silverstone FT02, very good airflow/noise, simple and nice look makes it ideal for me. + handle (as seen in
Thanks to everybody for suggestions!
