Wi-Fi Help
Solved by bbrooking18,
Should be fineI did not know about these power line adapters. Just read up a bit on it. Sure that can be an option.
Thank you for recommending this. Apparently people say it is much more reliable than wireless.
I am trying to use micro center because I am going there after work.
How does this pair look to you? : http://www.microcenter.com/product/408944/AV500_Nano_Powerline_Adapter_Starter_Kit
