OK so I have been getting the BSOD when it gets to the boot menu.
I am on Windows 8.1.
Here's the things I have tried:
Safe Mode (no way to get in to it works)
Resetting over clocks
Recovery Disc (computer tries to load disc but just skips to OS drive again)
Recovery USB (doesn't get acknowledged)
Removing Graphics Card (Integrated Graphics weren't working so I don't even know if it worked)
Changing DVD drives (lost the cable I needed for it)
This perfectly explains how life is constantly against me.
Please help me. My computer is my life and I have no idea how to fix this.
https://linustechtips.com/topic/305445-please-help-me/
When you boot into windows if you hold SHIFT down it should allow you to choose other boot options, which should allow you to trouble shoot your system if you get a BSOD before that disconnect all drives besides your OS drive and select the recovery USB from the boot device manager and it should load that with no issue.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151679
Tried that.
USB won't get acknowledged.
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151698
Tried that.
Enable hot swap in your BIOS disconnect the OS drive when your booting your system and then it starts loading the USB reconnect the OS drive, its worked like that for me a few times, main due to Windows 8.1 trying to be dominate over everything thing else when booting.
|King Of The Lost|
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151712
What? Where would I find that and I don't understand what you mean.
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151722
In your BIOS you should be able to enable Hot drive swapping in the SATA control portion of your board, I'm not to sure were it would be since I don't remember MSI's BIOS layout.
|King Of The Lost|
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151736
Okay then what after that?
If it won't pick up my USB, how will this help at all?
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151748
Does the board see it in the BIOS Boot menu?
|King Of The Lost|
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151763
No that what I'm saying.
I can't even get in to Windows.
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151807
Have you done a Clear CMOS for the board yet?
|King Of The Lost|
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151824
No because its not a BIOS problem as I get in to the BIOS perfectly fine but its as soon as Windows takes over.
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151852
I asked if the USB is detected in the BIOS you said no, which is a issue meaning either the USB is dead or the BIOS can't recognize the USB, clearing your CMOS can sometimes help with that.
|King Of The Lost|
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151863
I used the USB like 30 seconds before I plugged it in so it may be the second.
Nvm I have a clear CMOS button.
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151878
Make sure the system is powered off but not unplugged when you do it.
|King Of The Lost|
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151898
OK so I was having problems but I found a way to get the USB recognised.
NOW my USB has the same problem as my DVD Drive and it just boots straight to hard drive again
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151961
Even if you try to force the system to boot from the USB?
|King Of The Lost|
https://linustechtips.com/topic/305445-please-help-me/#findComment-4151967
