Question on Thermal Paste
Go to solution Solved by MooseParade,
Just a quick little noobie question:
Does thermal paste come with a CPU Cooler, CPU, Motherboard, or do you have to buy it separately? (And if so, where and what cost?)
If it depends on the kind of components I have, I'm getting an i7-3770K with a Cooler Master Hyper 212 EVO and an Asus P8Z77-V LK Mobo.
The 212 Evo will come with a tube of TIM. It's decent. The best is IC Diamond 24 Carat which is about $18 a tube.
https://linustechtips.com/topic/30524-question-on-thermal-paste/
"Energy drinks don't make my mouth taste like yak buttholes like coffee does, so I'll stick with them." - Yoinkerman
https://linustechtips.com/topic/30524-question-on-thermal-paste/#findComment-390858
If you buy boxed CPU coolers there's often applied something onto the cooler.
I think many air coolers come with a little tube. Not sure if it's all that common with watercooling blocks though.
However it's always a good thing to have laying around. It's not that expensive and you might need it at a later point. Rather that, then having to wait for it, because it wasn't included :P
https://linustechtips.com/topic/30524-question-on-thermal-paste/#findComment-390863
I just bought a corsair H55 which had paste pre applied, but I wiped it off n applied some antec formula 7 stuff I already had.
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/30524-question-on-thermal-paste/#findComment-390959
