You can put the 280 in the top without removing the ODD bays.
From their Radiator Compatibility Chart:
Length of radiator restricted to 322mm with the ODD cage still in place.
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
https://linustechtips.com/topic/304107-help-with-define-r5/#findComment-4134832
Thanks but ì want to keep the top closed for it to be quite as possible
https://linustechtips.com/topic/304107-help-with-define-r5/#findComment-4149886
Is your PSU short enough for you to slide the HDD into it's rear position? I don't think you can hang the small HDD cage without modding (or having it look a little janky) because it's not designed to accept the posts that the other 2 cages use.  However, since mounting holes for the HDD cage line up with fan screw holes, you may be able to hang the cage upside-down after you remove the ODD bay + tray. No guarantees because Fractal uses offset fan placements at the top. But the grill has enough holes that you could probably jerry-rig it.
https://linustechtips.com/topic/304107-help-with-define-r5/#findComment-4150873
  • 4 weeks later...
thanks man i think ill just mod the cages to fit in the top, i have an aluminum welder.
https://linustechtips.com/topic/304107-help-with-define-r5/#findComment-4352771
