I'm doing the build in my sig. A friend of mine just convinced me to switch to AMD and a micro-atx mobo. I need wireless internet, and a black/blue color scheme. Ideas?
Just a guy who peaked at building back in the days of the GTX 980. If you see me here, assume i have technical knowledge akin to a committed hobbyist builder back then. If something's changed, you'll need to tell me(nicely plz). I'm probably asking for help with the modern build scene since I have no clue what's going on.
https://linustechtips.com/topic/303881-moboprocessor-help/
Well, I'll try to convince you BACK to intel's side. They are just straight up better for gaming. And by chance, the CHEAPEST mobo for LGA 1150 is a blue/black scheme.
Here: http://pcpartpicker.com/part/msi-motherboard-h81mp33
Btw, about wireless lan: good luck. Get a USB adapter.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/303881-moboprocessor-help/#findComment-4129974
please go with intel...its more powerful and you can upgrade later on, while with AMD you can't
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/303881-moboprocessor-help/#findComment-4130059
phine... So. I don't want cheapest, I want most expensive i can get and not break 750 usd on my build.
https://linustechtips.com/topic/303881-moboprocessor-help/#findComment-4130102
Oh... you have 750$ + the 280 you already own? WOW. You have a pretty hefty budget. Anyway, here's my build. Best parts are: the blue theme (as requested), the windows copy (which people often don't include) and you can SLI in the future, if you want so. Prices can be cut down if you want, but here's how it goes:
EDIT: I just forgot the case =P. Oh well, you can cut down on the 2TB HD. You can also save 10$ by getting ASRock instead of MSI.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.95 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler  ($25.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  ($119.89 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($69.98 @ OutletPC)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($62.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($78.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($92.00 @ B&H)
Total: $734.78
Generated by PCPartPicker 2015-02-03 19:31 EST-0500
https://linustechtips.com/topic/303881-moboprocessor-help/#findComment-4130193
  • 4 weeks later...
