so i have my H100i in a pull on the "outside" of my case (there isnt enough room for the rad and the mobo inside the case). the thing is that i have it in pull so since its not (wasnt) filtered i would find some dust depositing on my GPU. what i did was get a used pantyhose and cut some holes and put it on the plastic cover that originally came with the case. so can a pantyhose be used as a proper air fiter?
PROJECT MOGARCPU: i5 4690k @ 4.9 Ghz CPU CoolerCorsair H100i in Pull on top Motherboard: Gigabyte Z97X-Gaming GT GPU: Gigabyte GTX 1080 G1 Gaming Edition RAM: Corsair Dominator Platinum (2x8GB) 2133 Mhz  PSU: EVGA G2 850W SSD: Samsung EVO 840 250 GB HDD: WD Black 1TB Case: Cooler Master CM Storm Scout II
https://linustechtips.com/topic/303814-makeshift-air-filter/
Pantyhose works fine as a filter.
https://linustechtips.com/topic/303814-makeshift-air-filter/#findComment-4129155
how "fine" exactly?
https://linustechtips.com/topic/303814-makeshift-air-filter/#findComment-4129165
It'll work fine. People have done this with Mac's, too.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/303814-makeshift-air-filter/#findComment-4129167
how "fine" exactly?
Not the absolute best option for a fan filter, but it still filters out plenty of dust.
https://linustechtips.com/topic/303814-makeshift-air-filter/#findComment-4129178
inb4 mac cooling is already inadequate :P
https://linustechtips.com/topic/303814-makeshift-air-filter/#findComment-4129190
what would be a better option?
https://linustechtips.com/topic/303814-makeshift-air-filter/#findComment-4129192
I've tried the partyhose option and it was too restricted to allow any decent amount of air flow (could just be the pair I used were just too fine)
In the end I gave up and just picked up a silverstone's magnetic fan filter for $5
3770k, Asrock Extreme 4, 16GB Dominator Plat, AX760i, 250GB BX100, 1.5TB Seagate, Win 7 Home Prem
https://linustechtips.com/topic/303814-makeshift-air-filter/#findComment-4129506
