Was watching a YouTube video on cable management on desks and the guy uses hot glue to mount devices under the desk to help keep cables tidy too .. not sure whether that's a good idea or not, what you guys think?
Akasa Venom Viper Full Tower Case | Intel i7-3930k @ 3.20Gh | Corsair 240Gb GT SSD Raid 0 | Samsung 23" LED 1080p FULL HD (x2) MSI Big Bang-ZPower II Socket 2011 XL ATX Board | Gigabyte GTX 680 | Windows 8.1 Pro | WD Caviar Red 3Tb HDD | Akasa Venom Voodoo high Performance CPU Coolerr | TP Link Wireless N DualBand | Pioneer BDR optical Drive | Corsair Vengance 16Gb Ram
https://linustechtips.com/topic/303747-hot-glue/
I assume it was the Barnacules video. Yeah, it's okay to do so long as the things are insulated and you aren't just glueing bare wires & PCBs.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128232
If you let the glue cool off a bit (for a second~) before putting the wires into it, then it's perfectly fine....and even if you don't let it cool off, it's still probably fine.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128236
Its perfectly fine, I hot glued both my powerstrips under my desk and it holds em nice and tight.
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128241
It works no problem I've seen that video but is less modular since when you need to add a cable you'll need to power up your hot glue gun or cut off some glue to remove one.
I personally love theses clips they are awesome:
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128255
Barnacules?
I personally wouldn't use hot glue on my desk.
You can try but it will look AWFUL if you can see the glue. You could buy one of those cable
management organizer box things or zip-ties.
yea its Barnacules , I have just never seen people hot gluw stuff to desks when it comes to electricals .. its a first for me so wanted to see what other people think
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128263
where would I find those? im based in the UK
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128270
It's perfectly fine, won't really harm anything.
blackshades on
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128272
Velcro strips are your best friend. Lets you easily take cables down and put them back up
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128312
I can't seem to fine the large flat ones but there are smaller ones I can find on amazon:
Medium-small ones:
http://www.amazon.co.uk/Black-Adhesive-Backed-Adjustable-Clamps/dp/B005MN2QHK/ref=pd_cp_kh_0
Small ones:
http://www.amazon.co.uk/Black-Plastic-Rectangle-Cable-Self-adhesive/dp/B00Q6ZC5U6/ref=sr_1_104?ie=UTF8&qid=1422995296&sr=8-104&keywords=adhesive+cable+clips
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128370
Hot glue is quite common inside of electronic components to tidy up the wires and hold them away from places they shouldn't be, very handy when DIYing projects. I never thought about using it under a desk... but now that I have the idea in my head I'll likely give it a try.
https://linustechtips.com/topic/303747-hot-glue/#findComment-4128810
