This is my first build. Although I posted before I've made significant changes to lower the costs, as well as upgrading some parts (in some cases to better parts with cheaper prices)
Current Build
http://pcpartpicker.com/user/DeathRtH/saved/1R3S
I chose
750W PSU: in case i decide to upgrade.
Azza Genesis 9000: For a large case size, with a large amount of stock fans.
HDD's: I basicly went with the cheapest i could find that had good reviews.
GPU: i went with the 780 GPU since, as far as i can tell its the best GPU short of getting a titan.
Xeon Processor from what i can tell, nearly the same as an i7 without an integrated GPU. but with an Nvidia 780 GPU i shouldnt need any integrated Gpu anyways.
Patriot Viper 3: Someone posted this on my previous post, not only was it cheaper than the RAM i had in my build before but it was faster.
Windows 7 Home Premium. From what I've heard windows 8 is not for gamers so I went with the Cheapest W7 i could find.
MOBO: this is the motherboard that ive had recommended to me the most.
Uses for PC, Mostly gaming but i do plan on getting into gave development, and would need to run programs for it, 3-D Modeling ETC.
The main questions I have, Price reduction and cases, I want to stay in Full tower (i like the ability to add extra fans/upgrade current onesand I like the looks of a full tower). but any help on MOBO is appreciated. Also, im not sure if i should go with W7 Home premium. or go with Professional.
Professional is more but has alot more compatability (as well as a higher cap on RAM incase id ever need to upgrade).
I also plan on running a 1920 x 1080 Display if that matters.
Edited by DeathRtH
https://linustechtips.com/topic/30372-first-build/
Windows 8 is for gamers considering you get like 6-10+ more frames and my question is are you really going to get into game development? I see a lot of posts for people wanting to make builds and everyone says "I am going to be doing recording and video rendering" and they don't, because YouTube is a big thing. Do you really think you are going to do that? Because game development is a large step, are you taking any classes? Do you know how to program anything? Because if the answer is no and you know in your heart you won't than be true to yourself and just get a gaming/all purpose rig. You will be a lot happier.
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
https://linustechtips.com/topic/30372-first-build/#findComment-388689
Yes i do plan on going into game development, currently researching the classes ill be needing, also plan on doing stuff on youtube, already have a few videos but because my rigs so old they are terrible quality. I did do some Mods for Oblivion and Fallout 3, and plan to do alot of skyrim stuff when i get this rig. (as well as minecraft but that doesnt realy matter for this) and any other games i can find worth modding. as for Windows 8, does it have many compatability issues like Vista and Windows 7 had? i know alot of those were fixed but i play ALOT of MMO's (Vindictus,Perfect World among others) and compatability would be a big worry for me.
https://linustechtips.com/topic/30372-first-build/#findComment-388700
Alright then it sounds good. I don't think it does. I know it has issues with games thar are 10+ years old though
https://linustechtips.com/topic/30372-first-build/#findComment-388716
Just changed the GPU in that build to
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130918&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
seems nobody has the 780 Superclocked in stock, this is the same price and seems better.
Seems from what people are saying theres no major difference between W7 and W8 performance so ill have to look up videos on the interface, been using the classic interface for about 12 years so thats where id be worried most of all.
https://linustechtips.com/topic/30372-first-build/#findComment-388769
Ram prices constantly change. Right now, this is cheaper, has lower heatsinks (less cooler height problems), and has the same performance: http://pcpartpicker.com/part/a-data-memory-ax3u1600gw8g92g
Just look at the memory at the top here to determine the cheapest ram sticks right when you purchase your parts: http://pcpartpicker.com/parts/memory/#sort=a8&qq=1&s=301600,301866&z=16384&c=90&n=2
As for the motherboard, you don't need such an expensive one. Mobos of that caliber often have better power delivery for better overclocking which is irrelevant since you won't be doing that with the xeon.
This will do just fine: http://pcpartpicker.com/part/msi-motherboard-b75ag43
If you plan to sli, get this instead: http://pcpartpicker.com/part/asus-motherboard-p8z77vlk
You should get a bigger ssd. 60gigs fills up pretty quickly. This ssd has great performance and is relatively cheap right now: http://pcpartpicker.com/part/kingston-internal-hard-drive-sv300s37a120g
https://linustechtips.com/topic/30372-first-build/#findComment-389472
After adding parts this is what i came up with.
is there any good qaulity Full Tower cases that are cheaper without sacrificing looks?
edit im missing stuff in that let me fix it.
Edit: Fixed
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor  ($199.99 @ Microcenter)
Motherboard:  MSI B75A-G43 ATX  LGA1155 Motherboard  ($78.98 @ SuperBiiz)
Storage:  Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk  ($84.99 @ Microcenter)
Video Card:  EVGA GeForce GTX 780 3GB Video Card  ($659.99 @ Amazon)
Case:  Azza Genesis 9000 (White) ATX Full Tower Case  ($149.99 @ Newegg)
Power Supply:  Corsair CX 750W 80 PLUS Bronze Certified ATX12V Power Supply  ($79.99 @ Microcenter)
Operating System:  Microsoft Windows 7 Home Premium Full (32/64-bit)  ($169.95 @ Amazon)
Total: $1628.84
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-06-28 04:23 EDT-0400)
https://linustechtips.com/topic/30372-first-build/#findComment-389765
Thanks im looking at that stuff now
SSD tho, i heard the best brands are Samsung and OCZ, has that changed?
One of the best ssds around is the samsung 840. There are more high tiered ssds now and the difference of speed is hard to tell in real life between them.
The story is different if you compare a higher tiered and a lower tiered ssd.
Looks are purely subjective. I could suggest the NZXT Phantom: http://pcpartpicker.com/part/nzxt-case-phan001wt
It also happens to be the case I use.
https://linustechtips.com/topic/30372-first-build/#findComment-391883
If I were you, I would definitely change the OS from Win7 to Win8, first of all, you can get Win 8 for $89/$130(pro) - $90-$40 cheaper, and future proof, you just get a normal start menu, there are A LOT of options(free and paid) which improves the use, and then I'd invest in something or just save money for a bigger upgrade, like a 27" 1440p monitor - good for editing photo/video with better color reproduction and programming/modeling :D
https://linustechtips.com/topic/30372-first-build/#findComment-392016
I dont see any USB 3.0 on the top =[ i knew there was a reason i didnt go with that, i like the looks but the USB3.0 ill be using alot when i get an external HDD  and id hate having to ninja over a large case to plug it in, ill have to look at the other phantoms cus i know theres a few models to see if they have any with a 3.0 port on top or in front.
https://linustechtips.com/topic/30372-first-build/#findComment-392641
There's a usb 3.0, usb 2.0, esata, mic, and headphone port/jack at the top.
https://linustechtips.com/topic/30372-first-build/#findComment-392648
Not sure about W8 ive heard alot of mixed stuff about it, as for 1440P monitors, about how much do those run? i was looking at this for a monitor, mainly for how adjustable it is
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236313
https://linustechtips.com/topic/30372-first-build/#findComment-392662
i just double checked on the page, and watched the video
  • 1 x HD Audio/Mic, 2 x USB 2.0, 1 x eSATA
 sadly no USB 3.0, im looking up the other phantoms now
I know it says 2x usb 2.0 but I ordered it from Newegg which says the same thing. It comes with a usb 3.0 port at the top and a usb 3.0 header as well.
https://linustechtips.com/topic/30372-first-build/#findComment-392820
Thanks. ill change that now.
Case:  NZXT Phantom (White) ATX Full Tower Case  ($108.35 @ Amazon)
Operating System:  Microsoft Windows 7 Professional SP1 (OEM) (64-bit)  ($128.99 @ NCIX US)
Total: $1552.92
(Generated by PCPartPicker 2013-06-28 21:07 EDT-0400)
Edit- Changed OS
https://linustechtips.com/topic/30372-first-build/#findComment-392895
Looking at included fans, vs optional, i want to have as many fans as possible
it seems to have open slots for a 200/230MM fan a 140MM fan and another 200MM fan, what fans would be recommended?
im not to worried about noise, i use Turtle Beach X12's so i dont hear alot of it, but if quieter fans arent to big of a difference id go with those
https://linustechtips.com/topic/30372-first-build/#findComment-393110
There's not much point to adding more fans. The fans that come with the case are quite adequate.
https://linustechtips.com/topic/30372-first-build/#findComment-393789
ah, okay, thanks for all the help..im actualy thinking i cant do anything to make this build cheaper....any ideas to make it faster without breaking the price? lol  :blink:
https://linustechtips.com/topic/30372-first-build/#findComment-395671
Not really.
https://linustechtips.com/topic/30372-first-build/#findComment-395961
Well...guess its as good as its gonna get then o.O thanks...well now im not sure what im going to be doing if im not researching PC parts 6 hours+ a day
Spend time on other threads like me?
https://linustechtips.com/topic/30372-first-build/#findComment-397129
Not realy, i feel i cant realy help other people until ive actualy built a gaming PC. right now im just watching some livestream on twitch lol
You could always ask questions on things you read on the threads. If you couldn't tell already, us LTT members are quite eager to help.
https://linustechtips.com/topic/30372-first-build/#findComment-397179
Cool =D. is there a section for Peripherals? Controllers/Headsets/Mice etc? cus im looking into getting a few gaming peripherals to make my gaming a bit less reach over 10 keys to do somthing lol.
Edit: Found it sorry i might as well be blind.
https://linustechtips.com/topic/30372-first-build/#findComment-397463
