i recently purchased a GTX 980 and im having in game issues
Battlefield 4
Dying light
Far cry 4
in game im running @1080p  setting on ultra. during some play sessions my frames will not go over 20-40 fps no matter how low i crank the settings.
and the problem wont resolve it self until i reboot my PC and than my FPS will return to normal. 90FPS - 160fps
it has happened on more than one occasion. im wondering what could be the issue is it my pc is bottle necking or something else?
what can i do to prevent this ?
help please!!!
https://linustechtips.com/topic/303533-gtx-980-problems/
Might be driver issues. I had something like this happen before and required a driver reinstall to fix.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/303533-gtx-980-problems/#findComment-4124744
temps at the highest is 71C
case AIR 240
I7 4790k @4.6
32gb hyperX @1866mhz
Asus Maximus Gene 7 mAtx
samsung 250gb ssd
kingston 1tb harddrive
How old is your Windows installation? Can you close the game and open it and be fine? Can you open a different game and be fine? Did you re-install Windows after you upgraded your PC? (If you didn't build from scratch.)
https://linustechtips.com/topic/303533-gtx-980-problems/#findComment-4124756
windows 8.1 about 2 months old....
i just built this PC and also new to PC gaming. the NVIDIA Geforce experiance progame says all drivers are up to date
no exiting game and reopening doesnt solve the issue only a full reboot will solve it. this is about the 5th time this has happened and its becoming on a more often basis
https://linustechtips.com/topic/303533-gtx-980-problems/#findComment-4124773
Remove drivers completely, restart and reinstall. See if that fixes it. Monitor the GPU usage during Games with something like MSI afterburner.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/303533-gtx-980-problems/#findComment-4124778
will MSI Afterburner work on an EVGA card ?
probably a dumb question i know?
Dont worry its not a dumb question:).
Yes it will. Msi Afterburner,Asus GPU tweak,EVGA precision X are all built on the same framework. Msi AFterburner is just the best of the lot.
https://linustechtips.com/topic/303533-gtx-980-problems/#findComment-4125527
