I currently have one GL2420 which I bought quite a while ago.
I am planning to add two monitors to it. When I went looking around the GL2460 seemed to be the cheapest 24" around. Judging by the model number its just 4 generations above my current monitor but I don't know.
Does anyone know anything about this monitor and if I should save up for a more expensive monitor? Any specific downsides to it?
Thanks for any answers.
Here's a quick link: http://www.benq.com/product/monitor/gl2460/
__________________________
Also could anyone recommend any good cheap wall mounts for the monitors. They need to be able to tilt inwards and I need to be able to buy them in the UK.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/30348-benq-gl2460/
the gl2450 what i have is really good so i would immagine the gl2460 to be just as good or better
I did a thing once and it was awsome: https://soundcloud.com/jamese666/junkhead-cover-with-vocals
https://linustechtips.com/topic/30348-benq-gl2460/#findComment-388500
If you want 3 monitors it would probably be better to get a couple screens with thin bezels like the acer 23 H236HLBID or the asus mx239h.
https://linustechtips.com/topic/30348-benq-gl2460/#findComment-388914
I would but the Acer doesn't sell in the UK and the Asus costs twice the price of the BenQ. :(
https://linustechtips.com/topic/30348-benq-gl2460/#findComment-389798
Oh well then I would at least try to get something with an IPS panel that way when you have the screens at an angle the colors won't look bad.
https://linustechtips.com/topic/30348-benq-gl2460/#findComment-390514
