Unity 3D Best first-person character controller script?
I'm a bit also confused with your question. If you're making it for pc/linux/mac/web player you can easily build the controller script using the free stuff included in unity(assuming you have a decent amount of knowledge/experience in c#, js etc). If it were for mobile use your question would make sense since creating your own virtual controls is a real hassle and the already existing assets paid or free have their own pros and cons.
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
You're probably better off learning how to code your own movement script since it will be tailored to your specific needs. Its not all that difficult since a lot of the grunt work is provided by the engine. All you just have to do is a little bit of math to tell the engine how that object is supposed to move. Then the rest is just positioning the camera and setting an appropriate collider within a prefab which the script is attached to.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
Its for pc, I think I'll just make my own. I know very little. of C# or Javascript. Which should I learn for this purpose? Which is easier?
Thanks, I think I'll try to make my own.
