Hi,
I recently built my rig but with all the fans connected to the fan hub included in the case (phanteks enthoo luxe).
However this meant that I could not change the fan speed so my pc sounds like a jet engine...
So I tried to plug the fan headers into the motherboard fan slots but when I booted it up there was a error message saying cpu boot error
Any help would be great
Thanks!
https://linustechtips.com/topic/302848-boot-error-help/
Do you not have any other PWM fans? It sounds like a problem with the PWM circuitry in your fan. You can try DC power control on a 3-pin header.
Thanks for the help however the cpu fans seem to be working so i disabled cpu fan monitoring in the bios and it now works perfectly (idle 28 degrees plus the fact that i live in Australia which is really hot)
https://linustechtips.com/topic/302848-boot-error-help/#findComment-4115670
Excellent. Glad it's working for you ;)
https://linustechtips.com/topic/302848-boot-error-help/#findComment-4115684
