Will it fit?
Go to solution Solved by the jolly roger,
Kind of a stupid question, but I'm about to buy a 212 evo but I'm not sure if i'll fit...
I have a Fractal Design ARC Mini R2, and the ram is HyperX Fury (it's not a bit stick...)
yes, max cpu cooler height is 165mm and hyper212 evo is 158
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/302439-will-it-fit/#findComment-4109758
It'll do fine.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/302439-will-it-fit/#findComment-4109770
