So, I recently purchased this strip of RGB Lights. Here: http://www.amazon.co.uk/Tingkam%C2%AE-Waterproof-5050RGB-Lighting-lighting/dp/B00H7T7XA2/ref=sr_1_sc_1?ie=UTF8&qid=1422811345&sr=8-1-spell&keywords=TingkamRGB+Light+strip
I would like to have them in my rig. My motherboard is the Asus Maximus VII Ranger. To my knowledge the only way to get them on is to use the wall adapter with the white box thing then to the strip. The connectors on the strip are female and they look like 'mini molex?' Is there a way to plug these into my rig and still have RGB capabilities?
Here is the RGB strip I bought http://imgur.com/a/VdnC6
https://linustechtips.com/topic/302389-rgb-light-strip/
Nope. The white box is the RGB Controller. I've seen people mount the box in a 3.5" bay and instead of plugging it into their wall connect it to the PSU via some soldering and molex
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4108700
http://imgur.com/UB86LiJHow can that be connected to a psu. The only connections that are spare on my PSU are Molex ones
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4108844
Chop the cable open and wire it up to the psu.
Make sure you do it properly and do research.
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4108897
The NZXT HUE uses the same kind of RGB LEDs with the same kind of connector (allthough i think it is a male connector on the LED). So if you can pick up a 2nd hand NZXT HUE you could use that to controll the LEDs.
Or of course do somer soldering witchcraft which is cheaper. :P
who cares...
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4108939
You need an adapter like this to connect to your PSU or re-wire it yourself using an old 2.1mm jack. As for the LED to the controller (white box) you connect those 4 pins on the LED's to the controller.
T1Lji3FitgXXXXXXXX_!!0-item_pic__45651_z
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4111248
Mine is taking so long to get here I almost want to just buy it on Amazon!
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4114160
It is actually pretty easy to rewire. I'm an idiot and I have rewired fans to external power supply cords several different times. However, if you don't have the tools to do it or a book to get basics from, probably not the best idea.
I would, if I were you, just get the adapter and be done with it.
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4114303
As @Albatross said it's fairly easy to wire it yourself as long as you have a 2.1mm jack and a molex you can basically just cut off the other end of the molex and rewire it yourself by soldering or twist together and insulating.
http://www.amazon.com/StarTech-Molex-Power-Adapter-SATAPOWADAP/dp/B00009YFTI/ref=sr_1_2?ie=UTF8&qid=1422852663&sr=8-2&keywords=molex&pebp=1422852684801&peasin=B00009YFTI
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4114589
No I'm just saying it is taking so long to ship from moddiy.com
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4114719
Hi! We sell LED's and controllers. Our controller has an included adapter for molex! At the below links you can see our LED and controller:
LED: http://modguru.net/product/led-strip-rgb/(Out of stock, will be in stock again in a couple of days)
Controller: http://modguru.net/product/rf-rgb-controller/
Contact us for a quotation or a chat [Modguru shop] [Facebook] Creating the highest quality products ever
https://linustechtips.com/topic/302389-rgb-light-strip/#findComment-4134953
