Split between two Mechanical Keyboards.
Solved by gts250ftw,
well it also depends on if you want one with a numberpad or without....also i believe the CM keyboards are made in the same factory with filco...meaning it should be good quality...
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
