C: Problems using char with %s and %c
#include <stdio.h>
#include <stdlib.h>
int main()
//Declaración de variables
char lcTipoVehiculo[10], lcHoraAlta[3];
int liNumeroPasajeros;
//Entrada de datos
printf("Ingrese tipo de veh%cculo (Cami%cn %c Autom%cvil): ", 161, 162, 162, 162);
scanf("%s", lcTipoVehiculo);
printf("N%cmero de pasajeros: ", 163);
scanf("%d", &liNumeroPasajeros);
printf("Hora de alta congesti%cn (Si %c No): ", 162, 162);
scanf("%s", lcHoraAlta);
//Procesamiento
if (lcHoraAlta == 'SI' || lcHoraAlta == 'si' && lcTipoVehiculo == 'AUTOMOVIL' || lcTipoVehiculo == 'automovil' && liNumeroPasajeros >= 3)
printf("\nN%c paga peaje.\n", 162);
else if (lcHoraAlta == 'SI' || lcHoraAlta == 'si' && lcTipoVehiculo == 'AUTOMOVIL' || lcTipoVehiculo == 'automovil' && liNumeroPasajeros < 3)
printf("\nTarifa: EUR$30.\n");
//Salida de datos
return 0;
The problem is that when entering data, the program stops and will not start reading any condition.
I have problems using char, with the %s an%c. I do not understand the difference and also with: char lcTipoVehiculo [10], lcHoraAlta [3];, not know exactly what number should I put.
I hope you can help me with this, I want to clarify my doubts using char.
https://linustechtips.com/topic/302291-c-problems-using-char-with-s-and-c/
%s is used for string (null terminated array of char) while %c is used for single characters...
I haven't touched C for a long time but I do remember that using scanf(%s, var) is not recommended... try using fgets() instead...
put that into a conditional loop that would exit upon getting a valid input...
like so:
printf(/*prompt*/);while(!fgets()){  printf(/*prompt*/);}
check the function's manual pages for additional details...
Edit:
for lcTipoVehiculo[] and lcHoraAlta[], the number inside is the size of the array (use a larger number to avoid buffer overflows)... it would be wise to initialize it to null first...
If you wish to recall a member of the array, the values range from 0 to sizeof(Array)-1.
If you wish to print the entire array as a string, make sure it is null terminated and use printf(%s) or puts().
like so:
Edit:
thanks men, but, if you open that progra, why it stops?
not sure... I don't have a compiler on me right now so I can't test it...
From my limited understanding of your language, your program is just to decide on something based on inputted values, right?
at what point does it stop?
Have you tested valid inputs? it could be that the values being put in are too large or are of an incompatible data type...
The reason the conditions don't trip is because the way you're interpreting your if conditions and the way the compiler is interpreting them are two different things. What you think is a string comparison the compiler sees as a pointer comparison, so there is no way the comparisons will ever yield a true result.
It sounds like you need to be using the std::string class to contain your strings so you get the comparison operators. Alternatively, you can use the strcmp function to do string comparisons as well.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
http://www.cplusplus.com/reference/cstring/strcmp/
You need to use strcmp() to compare strings.
Also, when using %s in scanf you should limit it to your buffer size with %Xs where X is your buffer size minus 1. Buffer overflows will cause you headaches.
Since your buffer size is 10 you would write:
scanf("%9s", lcTipoVehiculo);
main(i){for(;i<101;i++)printf("Fizz\n\0Fizzz\bBuzz\n\0%d\n"+(!(i%5)^!!(i%3)*3)*6,i);}
