I know some fans on start up start spinning backwards for a few seconds before going forwards. (I think its on MSI GPUs)
Does anyone know of a system that could make fans do this, like an adapter? It would be very good at getting rid of dust lodged in places.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/3018-reversing-fans/
I did a quick search and it seems that in most cases it would be impossible to use an adapter. In most circumstances you could just switch the polarity to the fan (ie switch the black and red) but many fans have "stuff" built in to prevent this, protecting the fan motor from possible damage. So, the best bet would be buy these special fans or adjust your internal case pressure to reduce dust.
https://linustechtips.com/topic/3018-reversing-fans/#findComment-39103
As far as I am >>aware<< you can't actually buy fans/adapters like this, they come in pre-built things like PSUs and GPUs.
The only good technology carried on from these things to case fans is that some mobos keep then fans powered on for a while after your system is off to allow it to cool down.
I may make this a modding project of mine to try and create a system that can reverse a fan for a few seconds at the start.
https://linustechtips.com/topic/3018-reversing-fans/#findComment-39121
As far as I am >>aware<< you can't actually buy fans/adapters like this' date=' they come in pre-built things like PSUs and GPUs. The only good technology carried on from these things to case fans is that some mobos keep then fans powered on for a while after your system is off to allow it to cool down. I may make this a modding project of mine to try and create a system that can reverse a fan for a few seconds at the start. [/quote']
Haven't heard of a fan mod before. I'd be interested to hear how that turns out.
https://linustechtips.com/topic/3018-reversing-fans/#findComment-39123
Here's something to try, attach the fan connector to a 3 pin to molex converter that you don't mind destroying. Pull the molex pins and hold them against the terminals of a 9 volt battery. Only when you hook up the black wire to the negative terminal and the red wire to the positive terminal will the fan actually do anything.
They probably just put a diode in the circuitry to prevent you from hooking it up backwards, so if you remove it, it should work. This could be completely inaccurate, though.
If it will only work on one polarity, the manufacturer did if for a reason.
https://linustechtips.com/topic/3018-reversing-fans/#findComment-39155
Here's something to try' date=' attach the fan connector to a 3 pin to molex converter that you don't mind destroying. Pull the molex pins and hold them against the terminals of a 9 volt battery. Only when you hook up the black wire to the negative terminal and the red wire to the positive terminal will the fan actually do anything. They probably just put a diode in the circuitry to prevent you from hooking it up backwards, so if you remove it, it should work. This could be completely inaccurate, though. If it will only work on one polarity, the manufacturer did if for a reason.[/quote']
Damn, I'll have to try that later.
https://linustechtips.com/topic/3018-reversing-fans/#findComment-39544
reveersing the spin is imo not practical. you wont suck dust out of your case when its already settled. let alone with some fans which won't move a lot of air (pc fans aren't really powerfull).
it wont work... maybe on your cpu block, but you are blowing that into the case. if you can aim it at an exhoust, it might work (for a bit). but thats it.
the anti dust functions from msi are also a bit overrated. and that heatsink is a lot thinner, so dust can barely settle in.
"People assume that time is a strict progression of cause to effect. But actually from a non-linear, non-subjective viewpoint, it's more like a big ball of wibbly wobbly timey wimey stuff."
Dont understimate my skillsz, you might look foolish.
https://linustechtips.com/topic/3018-reversing-fans/#findComment-41639
I don't think it would make much of difference to be honest as it's not easy to suck dust out of a case. You do also have fan filters after all' date=' maybe.[/quote']
The problem isn't quantity of dust that much. Its the very very tiny powder dust that does manage to get through. It just makes the whole system look coated with a gray powder if you forget to look after it for a few weeks.
https://linustechtips.com/topic/3018-reversing-fans/#findComment-42276
