So... How do i get rid of the grey outline around the text box. Its probably something simple but I just can't find it.
post-66999-0-29288700-1422724132_thumb.p
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/301712-libre-office-writer-help/
So, i figured out that changing the borders into none makes it so the pdf export doesn't show it, but its still on the .odt(?)
https://linustechtips.com/topic/301712-libre-office-writer-help/#findComment-4100123
