Hi guys,
I really like small form factor gaming pc's, but the cases on the market are still to big to replace a xbone or a ps4. So I designed a case thats smaller than a xbone and is more powerful.
post-8596-0-91623000-1422698962_thumb.jp
This design is smaller than the xbone, if I recall it's about 5.5 liters. It uses a small gpu (ie gygabite 970 itx), a flexible gpu riser and a tfx power supply to achieve this formfactor. This is almost what Linus mentioned in the Lian-Li video, but it has a psu inside rather than a power brick.
I don't have the money to build it, so I'm just throwing this out here.
Sincerely
-Prof 7
Note that I'm not responsible for eye damage due to poor grammar and spelling.
https://linustechtips.com/topic/301540-ltt-case/
Where would the PSU go? Assuming it's an SFX form factor PSU, of course (duh).
I'm rendering a picture for you atm so you can see where it goes, but it's not a SFX psu, it's a TFX psu because SFX was too big. (That's when you know that you got a small pc :P)
https://linustechtips.com/topic/301540-ltt-case/#findComment-4097916
I have acces to CNC machines and laser cutters, can you possibly put up the file somewhere?
You will need a cnc laser cutter, a cnc bending/folding machine and a 3d printer. I could put up some plans, but my pc is rendering atm
https://linustechtips.com/topic/301540-ltt-case/#findComment-4097920
Oh man, I didn't know TFX even existed. Good to know.
The TFX psu is on the left right (it was on the left when I had the solidworks file open).
Btw, the orange part is a one piece, 3d printed part. I made it orange to fit the LTT color scheme, and you can't make an LTT case without noctua :P
Edit: don't look too much at the internals, those are just placeholders. I made them based upon dimensions not upon looks. :)
post-8596-0-44981700-1422700996_thumb.jp
post-8596-0-06529500-1422701198_thumb.jp
I will have plans up shortly, but today and tomorrow I have somewhat limited time.
https://linustechtips.com/topic/301540-ltt-case/#findComment-4097988
Will get acces to a 3d printer within one or two years. :D Which will probably also be around the time i can afford to change my sytem up.
Thats MY opinion up there, not the ultimate option.
https://linustechtips.com/topic/301540-ltt-case/#findComment-4098680
Yeah, I won't get a desktop for a very long time either I think. It's almost the case that @LinusTech wanted the lianli pc to be. I would love to see it build actually
https://linustechtips.com/topic/301540-ltt-case/#findComment-4099322
